- Administrator
Beitrag
von fasse »
Yes this could be because it's a special syntax where your PHP crashed and if you don't have that syntax in your test files all works fine.
Please create a PHP file with the following syntax:
DAS
Beitrag
von DAS »
created file.. out put:
$test = 'My' . 'test' . 'text'; echo $test;
DAS
Beitrag
von DAS »
I changed the formatting to below:
<?php
$test = 'My ' . ' test ' . ' text.';
<?php
echo $test;
Now output is
My test text.
