Hiding the Contacts menu item
jorola
Beitrag von jorola »
We are using Groups and Roles for users to view membership info.
It's confusing to have two menu items to view membership, how to remove the Contacts menu item ?
I see that other mandatory menu items are not present when not an admin.
Why not this?
BR Johnny
Re: Hiding the Contacts menu item
It should be an easy way to show contact information of users you are able to view.
This view is role independent. Within the other view you must always select a group or role.
jorola
YES, I know that.
But I'd like to hide this menu item ie. select which user group may have access to it.
It's the only menu item that is visible for all, and in my case not desired.
Our members are 60+ and many are not skilled IT users, and thus gets confused by too many menu selections.
What is the problem in hiding it?
BR Johnny
