new user registration notification email not sent
ronhturner
Beitrag von ronhturner »
new user registration notification email is not being sent to the Admin email account.
carolereid
Re: new user registration notification email not sent
Beitrag von carolereid »
I’m experiencing a similar issue. New user registration notification emails are not being sent to the admin account on my side either. I’ve already checked the email settings and they seem correct, but the problem still persists. If anyone has found a solution or knows what might be causing this, I’d really appreciate your help.
Fivel
Beitrag von Fivel »
We’re seeing a similar issue on our end.
The email address field is missing from the registration form, even though it is enabled and set as mandatory in the contacts configuration - which means they never receive the confirmation email. We’ve double-checked the configuration, but we can't see anything wrong. This worked fine with v.4.x.
We are currently running version 5.0.9.
Has anyone identified a root cause or workaround for this?
Update:
I also noticed that the setting "Field is displayed during registration" in contacts profile-field is disabled/grayed out no matter what I try to change in the field-setting
Apexina
Beitrag von Apexina »
I'm also
ethancole11
Beitrag von ethancole11 »
In my case, the admin notification emails are not being sent after new user registration, even though all email settings look correct. I also noticed that the email field sometimes doesn’t appear properly on the registration form, which might be related to the problem.
I’ve already checked the contact profile field configuration and confirmed that everything is enabled, but the setting “Field is displayed during registration” being greyed out is also something I’m seeing.
ptarmiganammo
Beitrag von ptarmiganammo »
ronhturner hat geschrieben: 22. Mär 2026, 19:45 new user registration notification email is not being sent to the Admin email account.
Same issue here on 5.0.9. User confirmation emails are sent correctly, but the admin notification is never received. Has anyone confirmed whether this is a known bug or if there's a fix planned?
