Neuinstallation:"Strict Standards: Declaration of...&qu
Mansur
Beitrag von Mansur »
Ich möchte eine Neuinstallation machen (wie in der Anleitung
http://www.admidio.org/dokuwiki/doku.ph ... stallation)
Beim aufrufen von http:/.../admidio/adm_install/installation.php
(Anleitung Schritt 3)
Wird folgendes angezeigt:
Strict Standards: Declaration of TableOrganizations::readData() should be compatible with that of TableAccess::readData() in /opt/lampp/htdocs/admidio/adm_program/system/classes/table_organizations.php on line 50
Strict Standards: Declaration of TableMembers::readData() should be compatible with that of TableAccess::readData() in /opt/lampp/htdocs/admidio/adm_program/system/classes/table_members.php on line 114
Strict Standards: Declaration of TableRoles::readData() should be compatible with that of TableAccess::readData() in /opt/lampp/htdocs/admidio/adm_program/system/classes/table_roles.php on line 262
Strict Standards: Declaration of TableText::readData() should be compatible with that of TableAccess::readData() in /opt/lampp/htdocs/admidio/adm_program/system/classes/table_text.php on line 65
Strict Standards: Declaration of TableUserData::readData() should be compatible with that of TableAccess::readData() in /opt/lampp/htdocs/admidio/adm_program/system/classes/table_user_data.php on line 67
Strict Standards: Declaration of User::readData() should be compatible with that of TableAccess::readData() in /opt/lampp/htdocs/admidio/adm_program/system/classes/user.php on line 42
Strict Standards: Declaration of MySqlDB::db_error() should be compatible with that of DB::db_error() in /opt/lampp/htdocs/admidio/adm_program/system/db/mysql.php on line 15
border
Verwenden tue ich Admidio Version 2.1.10 und PHP Version 5.3.0.
Mache ich was falsch? Wie klappt es trotzdem?
Mansur
Mansur
Function split() is deprecated
Auch dies bekomme ich ständig auf allen möglichen Seiten...
Deprecated: Function split() is deprecated in...
Hallo Mansur,
dies sind alles Hinweise, dass Teile im Programmcode nicht den strengen Richtlinien bei der Entwicklung entsprechen bzw. teilweise Funktionen von PHP nicht mehr unterstützt werden. In der aktuellen Entwicklungsversion welche dann wohl die 2.2 wird, haben wir die Ursache dieser Meldungen behoben.
In der 2.1 werden wir dies allerdings nicht mehr nachholen.
Du kannst dieses Problem umgehen, indem du deine Meldungseinstellungen des Servers etwas tolleranter einstellst und nicht jeden Hinweis von PHP ausgeben lässt. Fehler sollten natürlich weiterhin ausgegeben werden.
