Calendar options
mbs
Calendar options
Beitrag von mbs »
Great bit of programming, I really need to change the event calendar drop downs currently set as "General|Training|Courses". is there a way to change the text and/or add more?
thanks
Thomas-RCV
Re: AW: Calendar options
Beitrag von Thomas-RCV »
Welcome in our support forum.
You can individually define new calendars and delete the basic calendars from installation.
Feel free to try our demo installation if you are not sure.
Best, Thomas
mbs
Re: Calendar options
Beitrag von mbs »
Thanks, Found it,
mbs
Beitrag von mbs »
How do I set default country to UK? Seems to default to Germany
Also how do I get maps to display?
Thanks
Please look in the profile preferences. There you can set the default country.
Thomas-RCV
Here is a link to our demo Installation in English:
http://www.admidio.org/demo_en
Please check out the preferences to get knowledge of possible settings of system and modules.
Kindly,
Thomas
