SMTP issue
mbs
SMTP issue
Beitrag von mbs »
Hi, email module works fine using PHP mail(), but no matter what settings i try with SMTP i keep getting an email failure message. I know it worked on 2.4.4, now on 2.4.6 and refuses to work. Any ideas? thanks
weissst
Re: SMTP issue
Beitrag von weissst »
Hello mbs,
I have done some tests with different Mailservers, but I can't reproduce it.
first of all, please try to update to Version 2.4.7 -> there was no update in this modul, but you never can be sure.
if possible, please give us more information about your error.
most of the time such errors happen, because of provider settings.
the only other idea i have at this moment is to update the PHPMailer version to an actual build.
because we are using an 1 year old in the actual Versions of Admidio.
hope this helps you,
Stefan
Re: SMTP issue
there was an Update of the phpmailer component in Version 2.4.6. Maybe there was a change that cause Problems within your Installation. Can you post the exact error Message?
Re: SMTP issue
A question, do you get the Error if you send the mail to a single person or only of you send it to a role?
mbs
Re: SMTP issue
Beitrag von mbs »
seems to error either to role or individual
SMTP Error: The following recipients failed: gemma@******.co.uk
The email could not be sent to gemma@*****.co.uk.
The following error occurred:
SMTP Error: The following recipients failed: *****@******.co.uk
Re: SMTP issue
Hi mbs,
please download this version of Admidio and try to send mail. We have update the mail component.
Give us feedback if this works or don't work.
