Navigationsbutton auf der Benutzerseite
red
Beitrag von red »
da ich viele Benutzer nachziehen und Daten prüfen muss, habe ich für die adm_program/modules/profile.php (Version 2.4.7) eine Navigation zum vorherigen/letzten (aktiven) Mitglied eingebaut. Wäre schön, wenn das so oder so ähnlich mal in den Hauptcode wandert.
Den Codebereich einfach in der profile.php nach der Zeile
require(SERVER_PATH. '/adm_program/system/overall_header.php');
einfügen.
Hier der Code:
// END Navigate to Prev / Next Member
//only active members
    $memberCondition = ' AND EXISTS
        (SELECT 1
           FROM '. TBL_MEMBERS. ', '. TBL_ROLES. ', '. TBL_CATEGORIES. '
          WHERE mem_usr_id = usr_id
            AND mem_rol_id = rol_id
            AND mem_begin <= \''.DATE_NOW.'\'
            AND mem_end    > \''.DATE_NOW.'\'
            AND rol_valid  = 1
            AND rol_cat_id = cat_id
            AND (  cat_org_id = '. $gCurrentOrganization->getValue('org_id'). '
                OR cat_org_id IS NULL )) ';
//Common request
$neighborsCommon    = 'SELECT usr_id, last_name.usd_value as last_name, first_name.usd_value as first_name,
                  email.usd_value as email, website.usd_value as website,
                  usr_login_name, COALESCE(usr_timestamp_change, usr_timestamp_create) as timestamp,
                  (SELECT count(*)
                     FROM '. TBL_ROLES. ', '. TBL_CATEGORIES. ', '. TBL_MEMBERS. '
                    WHERE rol_valid   = 1
                      AND mem_usr_id  = usr_id) as member_this_orga,
                  (SELECT count(*)
                    WHERE rol_valid   = 1
                      AND cat_org_id <> '. $gCurrentOrganization->getValue('org_id'). '
                      AND mem_usr_id  = usr_id) as member_other_orga
             FROM '. TBL_USERS. '
             JOIN '. TBL_USER_DATA. ' as last_name
               ON last_name.usd_usr_id = usr_id
              AND last_name.usd_usf_id = '. $gProfileFields->getProperty('LAST_NAME', 'usf_id'). '
             JOIN '. TBL_USER_DATA. ' as first_name
               ON first_name.usd_usr_id = usr_id
              AND first_name.usd_usf_id = '. $gProfileFields->getProperty('FIRST_NAME', 'usf_id'). '
             LEFT JOIN '. TBL_USER_DATA. ' as email
               ON email.usd_usr_id = usr_id
              AND email.usd_usf_id = '. $gProfileFields->getProperty('EMAIL', 'usf_id'). '
             LEFT JOIN '. TBL_USER_DATA. ' as website
               ON website.usd_usr_id = usr_id
              AND website.usd_usf_id = '. $gProfileFields->getProperty('WEBSITE', 'usf_id'). '
  WHERE usr_valid = 1'.$memberCondition.$searchCondition.'';
//Previous Neighbor
$sql=$neighborsCommon.'AND ((last_name.usd_value < \''.$user->getValue('LAST_NAME').'\')
OR (last_name.usd_value = \''.$user->getValue('LAST_NAME').'\')AND (first_name.usd_value < \''.$user->getValue('FIRST_NAME').'\') )
            ORDER BY last_name.usd_value DESC, first_name.usd_value DESC
			LIMIT 1';
$result_prevUser=$gDb->fetch_array($gDb->query($sql));
//Following Neighbor
$sql=$neighborsCommon.'AND ((last_name.usd_value > \''.$user->getValue('LAST_NAME').'\')
OR (last_name.usd_value = \''.$user->getValue('LAST_NAME').'\')AND (first_name.usd_value > \''.$user->getValue('FIRST_NAME').'\') )
            ORDER BY last_name.usd_value, first_name.usd_value 			LIMIT 1';
$result_nextUser=$gDb->fetch_array($gDb->query($sql));
//output
if(!empty($result_prevUser) && $gCurrentUser ->editUsers())
$prevUser=$result_prevUser['first_name'].' '.$result_prevUser['last_name'];
echo'<div style="text-align:left; float:left;">
                <a href="'.$g_root_path.'/adm_program/modules/profile/profile.php?user_id='.$result_prevUser['usr_id'].'"><img
                src="'.THEME_PATH.'/icons/back.png" alt="'.$prevUser.'" /></a>
                <a href="'.$g_root_path.'/adm_program/modules/profile/profile.php?user_id='.$result_prevUser['usr_id'].'">'.$prevUser.'</a>
</div>';
echo $gCurrentUser->viewProfile($result_prevUser['usr_id']);
if(!empty($result_nextUser) && $gCurrentUser ->editUsers())
$nextUser=$result_nextUser['first_name'].' '.$result_nextUser['last_name'];
echo '<div style="text-align: right;float:right;">
                <a href="'.$g_root_path.'/adm_program/modules/profile/profile.php?user_id='.$result_nextUser['usr_id'].'">'.$nextUser.'</a>&nbsp;<a href="'.$g_root_path.'/adm_program/modules/profile/profile.php?user_id='.$result_nextUser['usr_id'].'"><img
                src="'.THEME_PATH.'/icons/forward.png" alt="'.$nextUser.'" /></a>
           </div>';
Noch was ist mir aufgefallen:
Warum wird eigentlich der Navigationsverlauf zurückgesetzt(Zeile 109) und der Zurück-Button nicht angezeigt, wenn man auf seinem eigenen Profil ist?
Gruß red
Re: Navigationsbutton auf der Benutzerseite
Hallo Red,
vielen Dank für den Codeschnipsel. Ich hab ihn mir mal angeschaut. Das Problem bei der Navigation innerhalb des Profils ist, dass die äußere Liste, aus der das Profil aufgerufen wird, jedes mal anders aussehen kann. Wird es aus einer Liste aufgerufen hat diese indiviuelle Sortierungen und in der Benutzerverwaltung kann man auch filtern. Dies müsste man dann alles bei der Navigation berücksichtigen und macht die Funktion sehr komplex.
Hinzu kommt noch, dass es ab der 3.0 eine on-the-fly Sortierung der Tabellenspalten geben wird.
Ich selber habe mich schon mehrfach mit diesem Thema beschäftigt und mir ist bisher noch keine zufriedenstellende Lösung eingefallen, mit der man diese Probleme erschlagen kann.
Aber vielleicht kommt ja noch eine Idee.
red
Beitrag von red »
ja daran habe ich auch schon gedacht, allerdings ist das ganze vor allem dann interessant, wenn man eh alle Benutzer bearbeiten muss. Also aus der Benutzerverwaltung kommt, dass könnte man recht einfach über die History abfragen.
Alternativ kann man auch eine Rolle mit übergeben, in der man sich bewegen will. Wenn man dann einmal aus einer ganz anderen Liste kommt übergibt man einfach nichts. Damit sind wahrscheinlich fast alle Anwendungsfälle abgedeckt und man wird ja nicht gezwungen die Navigation zu verwenden :)
Ohne die Buttons ist es halt eine mühsame Klickerei alle zu bearbeiten, und in "normaler" Software zur Mitgliedsverwaltung gibt es solche Buttons eigentlich immer.
Gruß red
Hallo Red,
ich mach mir noch mal Gedanken. Vielleicht fällt mir eine gute Lösung ein.
