Written Communication auto brief or invoice number
berd
Beitrag von berd »
Hello,
The Written Communication plugin has 2 default fields "Betreff" und "Beschreibung".
Is it possible to add an extra field called "Rechnungsnummer" or "Briefnummer" which will generate an automatic incremental number? For example: 2014-001 then the next letter has 2014-002 etc.. the you can use it for simple invoice or brief auto number opportunities.
