Notice: Undefined index: enable_forum_interface
robh
Beitrag von robh »
Hello,
I have Zyxel NSA325 v2 NAS with Funplug ffp 0.7 and lighttpd.
PHP version: 5.4.19
MySQL version: 5.5.28
I installed Admidio 2.4.13 and receive the following error when login as admin;
Notice: Undefined index: enable_forum_interface in /admidio/adm_program/system/common.php on line 318
Please advise.
Thank you.
Regards, Robh
Bullseye
Re: Notice: Undefined index: enable_forum_interface
Beitrag von Bullseye »
Have u tried to downlooad again and take a reinstallation?
robh
Beitrag von robh »
Yes, I have deleted all folders and database, downloaded 2.4.13 again and installed again.
Now I get this message on login page;
Notice: Undefined index: db_version in /admidio/adm_program/system/common.php on line 302
Undefined index: db_version_beta in /admidio/adm_program/system/common.php on line 302
Also, in left hand section of the page it shows this message;
NOTE:
Database version %VAR1% does not comply with Admidio scripts %VAR2%.
Please contact the %VAR3%webmaster%VAR4% of the site.
Help please
Thank you.
Bullseye
Last two ideas are:
1. Trying admidio 3.0 b3 in my opinion it runs flawlessly.
2. Upgrading MySQL to 5.6
If that also wont work u have to wait for an developer.
I am at my wit's end.
robh
Beitrag von robh »
I tried installing 3.0.b3, it does appear to work ok and without errors.
However, it is no use to me, I need the membership fees plugin and it is not compatible with 3.0.b3
I tried upgrading MySQL to 5.6 and get this error;
CODE: 1
Can't create/write to file '/srv/mysql/tmp/ibOhf1wQ' (Errcode: 2)
LINE: 62
CALL: DBCommon->db_error()
LINE: 172
CALL: DBMySQL->db_error()
FILE: adm_install/installation.php
LINE: 496
CALL: DBMySQL->query()
Please help
Thank you.
thats not a Problem of MySql. It seems to me, that you have used version 3.0 Beta and after that you installed Admidio 2.4.13
Please try to delete all folders and all tables in database and then do a new clean install with version 2.4.13.
Regards
