Duplicate record created on bulk user import
TenX
Beitrag von TenX »
In User management > Additional functions > Import user(s), when I import a new CSV file with 'Existing user = Complement', some duplicate records are created.
The issue seems to be with only the records that have an apostrophe in the name (e.g. O'Connor, D'Arcy etc.)
It's easy enough to find and delete the duplicates but probably needs to be resolved. Thanks.
Re: Duplicate record created on bulk user import
Hi Tenx,
I will have a look at it, when there is time.
Thanks for the report.
Hi Tenx,
I have fix this and some other places where we might have problems with quotes in names.
Please wait for version 3.0.4
TenX
Beitrag von TenX »
Thank you! :D Will do.
