Some data fields in Own List not populating
TenX
Beitrag von TenX »
When creating Own List, and adding columns 'Start of membership' and 'End of membership', picking Role 'Member' and Member status 'Active Members'....
Click Display list button, no data under Start and End columns.
This is true for some other user profile fields I created, but not all fields. Logged in as webmaster with all permissions.
Re: Some data fields in Own List not populating
Hi Tenx,
I could not reproduce this.
Can you try to reproduce this on our playground http://spielwiese.admidio.org ?
TenX
Beitrag von TenX »
Seems to be working in the playground. I'll overwrite the Beta 2 files on my local server and try again.
TenX
Beitrag von TenX »
So I did a fresh installation on my local server with Beta 3. I started to configure User Profile fields by adding new ones, renaming a few existing ones, etc. I tested this issue after each change and it worked fine until I deleted the default "Country" field. Now when I pull an "Own List", I can't get the Start and End Membership dates to populate in the list as detailed in the original post.
With this description I could reproduce the error and fix it.
Thanks for the hint.
