Counter in links
Schwartz
Counter in links
Beitrag von Schwartz »
Hello Admidio
In the web-links, there is a counter shown.I would like a possibility to ( in settings for the links ) be able to decide if the link should be shown or not.
In the links.php there is a section with :
// get available description
if(strlen($weblink->getValue('lnk_description')) > 0)
$page->addHtml('<div class="admidio-weblink-description">'.$weblink->getValue('lnk_description').'</div>');
$page->addHtml('<div class="weblink-counter"><small>'.$gL10n->get('LNK_COUNTER'). ': '.$weblink->getValue('lnk_counter').'</small></div>
</div>');
++$j;
++$i;
Unfortunately I don't speak PHP. Could anyone tell me how to "disable" the showing of the counter-line ?
I have a feeling where it is, but I would like if an expert could tell me if and how it is possible to "deactivate" the counter-line
You can see an example here, and maybe see why I don't want the counter : http://www.energifremtiden.dk/c4d/tiere-1.html
Re: Counter in links
Hi Schwartz,
just remove or comment the following line:
You can set it to
//                $page->addHtml('<div class="weblink-counter"><small>'.$gL10n->get('LNK_COUNTER'). ': '.$weblink->getValue('lnk_counter').'</small></div>
Than it's disalbed.
Best regard
Schwartz
Hello fasse
First I only commented the line 175 and then I got a totally white screen in web-links.
I should of course "slash" both 175 and 176
Then I had it to work - Thank You
Kind regards
schwartz
