Custom Fields
Cristiano Panada
Custom Fields
Beitrag von Cristiano Panada »
Hi everybody
I have a question to ask.
Is possible to insert custom fields in the data sheet of the members ?
And at the same time, how to import members from a csv file ?
thank you all for the answer
Cristiano
Schwartz
Re: Custom Fields
Beitrag von Schwartz »
Hello Christiano
Yes - it is possible to insert custom fields.
And the import function is very very good.
You showld go in - User management and then additional functions.
Here You have :
import users
AND manage profile fields
I think You will also find that the import works very smooth.
Hope You are helped by this.
Cristiano Panada
Re: Custom Fields
Schwartz hat geschrieben:Hello Christiano
Here You have :
import users
Thank You Schwartz
I have found your explanation perfect
Cristiano
