silverches
Beiträge: 9 Registriert: 14. Feb 2016, 01:00
Beitrag
von silverches » 14. Jul 2017, 12:16
Hello,
I'm running 3.2.10 but for some reason the catpcha's aren't working. This was also the case in previous versions.
Phpinfo says GD is enabled.
Beiträge: 6356 Registriert: 12. Nov 2005, 16:06
Beitrag
von fasse » 30. Jul 2017, 11:11
Hi silverches,
are there some informations within the log?
Without other informations it's very hard to get the reason for this error since you are the only one reporting this
Best regards
silverches
Beitrag
von silverches » 7. Aug 2017, 17:38
Hi Fasse,
Sorry for the late reply, had notifications disabled. The logs gives no information. If i press view image it just says: Failed to generate captcha image, content has already been output.
This is most likely due to misconfiguration or a PHP error was sent to the browser.
Beiträge: 1148 Registriert: 12. Jul 2015, 13:21
Beitrag
von XimeX » 8. Aug 2017, 09:28
Did you modified any files?
Could you set $gDebug = true; in config.php and look in the logs again?
