PDO drivers - install
cschwab
Beitrag von cschwab »
Hi there. I'm a new user. Trying to get this to work, at least for now, on a linux box. I'm working with Ubuntu 14.04 and have Apache, PHP, and MySQL all up and running. I finally got through the installation of admidio and, on the last step, I got...
Installation of version 3.2.10
The connection to the database failed!
The following error occurred:
PDO does not support any drivers.
If I try to naviate to localhost/ (admidio is the only thing I'm running on apache right now, so it is in the "root" www directory), I get a simple text message:
[/quote]I'm not sure what PDO is or how to fix this. Any ideas?
Re: PDO drivers - install
Your PHP Installation has no PDO driver installed. You Must install MySQL or PostgreSQL driver.
