how to add link in heading (overview) & remove admidio from heading (Admidio overview)
amitabhmca
Beitrag von amitabhmca »
Please refer below screenshot and let me know
1) how can i remove Admidio from heading (circled)
2) how can i add links as similar to registration
admidio overview and link.PNG (15.88 KiB) 11381 mal betrachtet
Many thanks in advance..
thanks,
Amitabh
Re: how to add link in heading (overview) & remove admidio from heading (Admidio overview)
To 1)
https://github.com/Admidio/admidio/blob ... ex.php#L21
change to:
$headline = $gL10n->get('SYS_OVERVIEW');
To 2)
Look at this code:
https://github.com/Admidio/admidio/blob ... hp#L32-L61
The first section is for the links that are shown if you are logged in. the other section for logged out
amitabhmca
Hello XimeX,
Thanks for your reply..
can you suggest where exactly i should add the code forto show the link? I tried adding but getting error 500.
and the code should be as this?
$page->addHtml('
    <div id="Website_home_page">
        <small><a href="http://www.test.com/"><img src="http://test.com/adm_themes/modern/icons/home.png" alt="HomePage" /> Website Home Page </a></small>
    </div>'
>>>> code from https://github.com/Admidio/admidio/blob ... ex.php#L21
else
    // show login link
    $mainMenu->addItem('adm_menu_item_login', ADMIDIO_URL . '/adm_program/system/login.php',
                       $gL10n->get('SYS_LOGIN'), 'key.png');
    if($gPreferences['registration_mode'] > 0)
        // show registration link
        $mainMenu->addItem('adm_menu_item_registration',
                           ADMIDIO_URL . FOLDER_MODULES . '/registration/registration.php',
                           $gL10n->get('SYS_REGISTRATION'), 'new_registrations.png');
Thanks,
Amitabh
