Address field changed to Street with in Basic info Admidio-3.3.1 -
amitabhmca
Beitrag von amitabhmca »
Dear All,
I noticed address field changed to street in admidio-3.3.1..
Is it ok to simply rename the field to address? & it won't impact anything?
Please suggest?
Thanks,
Amitabh
Re: Address field changed to Street with in Basic info Admidio-3.3.1 -
Yes you can rename it within your translation. But you must then update this after every system update.
We think that street is the better name because you only save the street in that field and not the whole address.
amitabhmca
Thanks for the suggestion Fasse. I think you are right. I will leave it like that for now..
