How to undo Weblink (Multiple organization visibilty)
amitabhmca
Beitrag von amitabhmca »
By mistake, i clicked on below check box and now i am no more able to delete it?
Is there a way to delete with in admidio or can i just delete the link from database?
Re: How to undo Weblink (Multiple organization visibilty)
This should be the same problem as here and will than work with 3.3.3
viewtopic.php?f=20&t=7885&start=15#p28211
amitabhmca
Thank you very much Fasse.
Regards,
Amitabh
