Log-in without Right Hand SideBar
bryan
Beitrag von bryan »
We would like to achieve a higher level of site privacy - is it possible to configure a log-in screen that has no right hand sidebar? - with the sidebar present, those who visit the site can see information such as the Events scheduled, without having to log in - we would like to have a site where any information is only viewable by logging in
Thanks
Bryan
Schwartz
Re: Log-in without Right Hand SideBar
Beitrag von Schwartz »
Hello Bryan
You can for each module setup if the module should be available only when logged in.
Try look at this post : viewtopic.php?f=20&t=7803
I hope the post is useful. If it was not what you were asking for, then please add a new post here. Would like to know if you get it solved.
Kind regards
Schwartz
bryan
Beitrag von bryan »
Hi there - many thanks for your reply - the challenge is that the Only Users Logged In functionality (which is very helpful) does not appear to be across all of the modules? - for example, Downloads?
Kind regards
Bryan
amitabhmca
Beitrag von amitabhmca »
Hello Bryan,
Check out the screenshot. Permission to be set for folders. You can select whether folder to be visible to visitors.
Admidio - Download Permission.PNG (28.32 KiB) 22933 mal betrachtet
Thanks,
Amitabh
bryan
Beitrag von bryan »
Thanks!! Wasn't expecting to find it there and missed it
Cheers ... Bryan
