Installation script do not allow MySQL username
Ramses800
Beitrag von Ramses800 »
Hello,
I wanted to try Admidio and started the installation process, however I got stuck rather quick, my webhost(and mysql provider) automatically(and I can not change this) creates the username for the mysql in a format username@servernr, and when running the Admidio installation, the input form will not let me proceed, stating that "Please use the required format for user name"
Any hopes of getting the installation script to accept this format?
Ramses800
Re: Installation script do not allow MySQL username
Well, I managed to find the solution.
I just saved the config_example.php as config.php and edited it, uploaded to the server and, viola, the installation continued successfully!
I think the @ is the problem. We will fix this.
