Couple of small bugs? Version 3.3.14
timm
Beitrag von timm »
Hi, thanks for the great software we are looking to implement for a small charity I volunteer for. Just reporting a couple of little bugs I have found in this version.
1. Help text icons ... When editing the profile (profile_new.php) and the field has description text (usf_description), the help icon provides a link to a blank popup. Looking at function getHelpTextIcon in HTMLForm.php, it correctly gets the text for the user field (user_field_description) at line 1953, but then the test at line 1961 fails to find a language translation string and creates <a href> to msg_window.php?message_id=user_field_description ...
Should the test at line 1961 also check for $text being set and use the mouse-over help? if(Language::isTranslationStringId($textId) || $text != "" )
2. In modules/roles/roles.php, at line 272, the safeUrl parameters for vcard generation are not correctly specified and this gives an error and an empty vcard file.
array('mode' => '8', 'rol_id'. $rolId) should be array('mode' => '8', 'rol_id' => $rolId)
Thanks for your good work.
Tim
Re: Couple of small bugs? Version 3.3.14
Hi Tim,
thanks for the hints. I have fix this problems within the next version 3.3.15.
For problem 1 I have attached a new htmlform.php file that you can use and will create a popover for profile field descriptions.
Best regards
HtmlForm.php.zip
(17.35 KiB) 546-mal heruntergeladen
