Unable to update to version 4
I followed the steps for updating from version 3 to version 4, described here: https://www.admidio.org/dokuwiki/doku.p ... _version_4. However, I'm now getting a 500 error when I try to access Admidio.
My website is https://member.seattleoperaguild.org/ad ... /index.php
Re: Unable to update to version 4
Nevermind—the problem resolved itself when I tried using Safari instead of Chrome. I'll leave this post in case someone else runs into the same problem.
I have the same problem. But the solution of using the Safari instead of Chrome doesn't work for me. Safari shows a blank page, while in Chrome says HTTP 500 ERROR.
With any updates before version 4, I never had any troubles.
Which Chrome version do you have and which os (windows/ mac /linux)?
I am using MacOS Catalina 10.15.7 and Chrome 86.0.4240.75.
I also tried it using Safari on my Mac and my iPhone
I have tried it with Chrome 87 and MacOS 10.13 and everything works fine.
When did you get the 500er error? If you want to click on update or after successful update?
Is the error still there if you restart your browser?
The error comes immediately when I try to access the admidio directory. I also just tried to install a backup and reinstall v4.0.1. I tried this with several Browsers and I don't see the "menu screen" to update the database.
The PHP error log shows this:
[01-Jan-2021 15:50:30 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#0 /home/webky5ds2/html/mitgliederverwaltung-admidio/index.php(18): require_once()
#1 {main}
thrown in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php on line 162
Stack trace:
#1 {main}
[01-Jan-2021 15:50:32 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
[01-Jan-2021 15:50:33 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
Stack trace:
#1 {main}
Stack trace:
#1 {main}
Stack trace:
#1 {main}
[01-Jan-2021 15:50:34 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
Stack trace:
#1 {main}
Stack trace:
#1 {main}
[01-Jan-2021 15:50:35 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
Stack trace:
#1 {main}
[01-Jan-2021 15:50:47 Europe/Berlin] PHP Fatal error: Uncaught --> Smarty: Unable to load template 'file:index_reduced.tpl' <--
thrown in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/libs/server/smarty/sysplugins/smarty_internal_template.php on line 195
[01-Jan-2021 15:50:48 Europe/Berlin] PHP Fatal error: Uncaught --> Smarty: Unable to load template 'file:index_reduced.tpl' <--
[01-Jan-2021 15:50:49 Europe/Berlin] PHP Fatal error: Uncaught --> Smarty: Unable to load template 'file:index_reduced.tpl' <--
[01-Jan-2021 15:51:44 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
[01-Jan-2021 15:51:46 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
[01-Jan-2021 15:51:47 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
[01-Jan-2021 15:51:49 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
[01-Jan-2021 15:52:00 Europe/Berlin] [2021-01-01 15:52:00.432401] Admidio.ERROR: L10N: Could not found text-id! {"textId":"MEN_PLUGIN"} {"file":"/home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/classes/Language.php","line":119,"class":"Language","function":"get"}
[01-Jan-2021 15:52:00 Europe/Berlin] PHP Fatal error: Uncaught --> Smarty: Unable to load template 'file:index_reduced.tpl' <--
[01-Jan-2021 15:52:00 Europe/Berlin] [2021-01-01 15:52:00.791622] Admidio.ERROR: L10N: Could not found text-id! {"textId":"MEN_PLUGIN"} {"file":"/home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/classes/Language.php","line":119,"class":"Language","function":"get"}
[01-Jan-2021 15:52:09 Europe/Berlin] [2021-01-01 15:52:09.766221] Admidio.ERROR: L10N: Could not found text-id! {"textId":"MEN_PLUGIN"} {"file":"/home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/classes/Language.php","line":119,"class":"Language","function":"get"}
[01-Jan-2021 15:52:09 Europe/Berlin] PHP Fatal error: Uncaught --> Smarty: Unable to load template 'file:index_reduced.tpl' <--
[01-Jan-2021 15:52:23 Europe/Berlin] [2021-01-01 15:52:23.184330] Admidio.ERROR: L10N: Could not found text-id! {"textId":"MEN_PLUGIN"} {"file":"/home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/classes/Language.php","line":119,"class":"Language","function":"get"}
[01-Jan-2021 15:52:23 Europe/Berlin] PHP Fatal error: Uncaught --> Smarty: Unable to load template 'file:index_reduced.tpl' <--
[01-Jan-2021 15:52:24 Europe/Berlin] PHP Fatal error: Uncaught --> Smarty: Unable to load template 'file:index_reduced.tpl' <--
[01-Jan-2021 15:52:54 Europe/Berlin] PHP Fatal error: Uncaught Error: Call to a member function removeFunctionsNode() on bool in /home/webky5ds2/html/mitgliederverwaltung-admidio/adm_program/system/common.php:162
Stack trace:
#1 {main}
Zuletzt geändert von Smfo am 2. Jan 2021, 22:58, insgesamt 1-mal geändert.
Thanks for the error log. I think the problem will be with the subdomain.
I will try to test this.
I just tried to access the directory using a Virtual Machine with Windows 10: I was able to update the Database.
However right now. I still cannot access with any Mac Computer (Chrome or Safari) or with any iPhone (Safari).
But when I try to access the demo https://www.admidio.org/demo/ on the same Mac/iPhone everything seems to work fine.
Zuletzt geändert von Smfo am 1. Jan 2021, 20:21, insgesamt 1-mal geändert.
You're right! For testing I just changed the directory from the subdomain to a regular domain (also changed the URL in the config.php) and it works fine on Mac & iPhone.
I was not able to reproduce the error with my test at http://test.admidio.org.
But I try to resolve the error from your posted errorlog. Just try it and replace the unzipped attached file in the folder adm_program/system.
After that please try the update again.
- common.php.zip
- (3.26 KiB) 883-mal heruntergeladen
This works!!! Thank you very much for your help!
If I switch back the common.php you sent to me with the old common.php it still works! I don’t know why....
Thanks for your quick response.
I have integrated this fix for version 4.0.2.
I had the same issue, could also be fixed with updated common.php
