Manual members input
bahkeru345
Beitrag von bahkeru345 »
Hi I just started and checking this out
I wanna use this system just to monitor my members, is there anyway I can just input the names of my members and there expiration manually?
Thanks
Re: Manual members input
You can import members using CSV.
That is possible within the user management. Just use the funktion import users.
