Issue with update 4
jaco
Issue with update 4
Beitrag von jaco »
Hello, i have below issue while starting the update and no clue what to do. Please can you help. thanks.
Fatal error: Uncaught UnexpectedValueException: Settings name "registration_enable_module" does not exist! in /home/w15833/web/my.nes-ev.de/adm_program/system/classes/SettingsManager.php:134 Stack trace: #0 /home/w15833/web/my.nes-ev.de/adm_program/system/classes/SettingsManager.php(150): SettingsManager->get('registration_en...', false) #1 /home/w15833/web/my.nes-ev.de/adm_program/system/classes/HtmlPage.php(469): SettingsManager->getBool('registration_en...') #2 /home/w15833/web/my.nes-ev.de/adm_program/system/classes/Message.php(186): HtmlPage->show() #3 /home/w15833/web/my.nes-ev.de/adm_program/system/common.php(266): Message->show('Die Datenbankve...', 'Admidio - Updat...') #4 /home/w15833/web/my.nes-ev.de/index.php(27): require_once('/home/w15833/we...') #5 {main} thrown in /home/w15833/web/my.nes-ev.de/adm_program/system/classes/SettingsManager.php on line 134
Re: Issue with update 4
Hi Jaco,
please replace the unzipped attached files to the following folders and than try the update again:
SettingsManager.php. --> adm_program/system/classes
common.php --> adm_program/system
Please give a short feedback if that works for you.
SettingsManager.php.zip
(3.33 KiB) 751-mal heruntergeladen
common.php.zip
(3.43 KiB) 760-mal heruntergeladen
Hi Jaco,
alternativ you can call the update page directly
www.example.org/admidio/adm_program/installation/update.php
jaco
Beitrag von jaco »
Thank you very much. I will test it and let you know if it went well.
jaco
Beitrag von jaco »
Update went well. Thank you very much for the quick support.
