mass import of files into database
jaco
Beitrag von jaco »
Hello,
is there a way to do some kind of mass import of all files into the database? I have uploaded a bunch of files via ftp and now I have to click each file and folder by its own to import them into DB. Is there a way to click once and all files will be imported recursive?
I will be grandpa once I have clicked all files manually.
Re: mass import of files into database
Hi jaco,
since now it's not possible to do it recursiv. But it would be a good idea ;-)
Maybe if someone adds a folder than that folder should be added recursivly.
