Header text substitution
plenacomsa
Beitrag von plenacomsa »
Hello,
The header text saying "online membership management" can be substituted by other text? And if possible, how to do it?
Thank you
Linda
Re: Header text substitution
Hi Linda,
look for the line
<string name="SYS_ONLINE_MEMBERSHIP_ADMINISTRATION">Online membership management</string>
in the file adm_program/languages/en.xml.
There you can change the text.
plenacomsa
look for the line
Code: Select all
Hi there,
Thnx, worked perfectly.
Lots of appreciation for this great membership manager!
Kind regards
Linda
