initial redirection and overview
mathieu
Beitrag von mathieu »
I have just completed the installation of Admidio on my server.
it went smoothly. I created a couple of users. and things seems to work well.
two issues though.
when I visit the root url, it still redirects me to the installation page, and complains it was already installed.
how do I flip back?
I think it should just redirect to the login page.
second related issue, is that I can access the overview page without being logged in.
can I make this private?
the only two features that should be accessible to a non-authenticated user is
- to login
- to register
thank you
Re: initial redirection and overview
Hi mathieu,
your second related issue, the overview:
1. look at
https://www.admidio.org/dokuwiki/doku.p ... tomization
How can I customize the overview page ?
2. look at: adm_plugins
every plugin has a 'config_sample.php'.
you can/must create a 'config.php' for each plugin
3. when you are logged in, than look/modify the 'settings'
