HTTP 500 Error When Trying to Allow Registrations to Event
rknott
Beitrag von rknott »
I recently installed Admidio v. 4.0.9 and am really liking everything I am seeing. I have been doing some testing to figure out the most efficient way for me to utilize it.
The one problem I have run into so far is that I have a problem allowing me to Enable Registrations for an Event.
I can create an event and save it without any problems. However if I attempt to Enable Registrations for Event, no matter group/role I choose to enter into the Registration Possible For field, as soon as I select to save, I get an HTTP 500 error.
Can someone give me some troubleshooting ideas on what I should be looking for to assist me in resolving this?
Wanted to add, here is the error I am getting in my log, but I am logged in as admin, and as far as I can tell I should have access listed:
Got error 'PHP message: PHP Fatal error: Uncaught AdmException: Category of the role could not be set\n because the category is not visible to the current user and current organization. in /home/UserXXXXX/domains/MyDomainXXX.com/public_html/admidio/adm_program/system/classes/TableRoles.php:496\nStack trace:\n#0 /home/UserXXXXX/domains/MyDomainXXX.com/public_html/admidio/adm_program/modules/dates/dates_function.php(485): TableRoles->setValue('rol_cat_id', 8)\n#1 {main}\n thrown in /home/UserXXXXX/domains/MyDomainXXX.com/public_html/admidio/adm_program/system/classes/TableRoles.php on line 496', referer: https://MyDomainXXX.com/admidio/adm_pro ... ine=Events
Thanks so very much!!
Becky
rknott
Re: HTTP 500 Error When Trying to Allow Registrations to Event
Update to my issue: I have created 3 different organizations that I am testing with. When I use the 'original' organization that I created at install, it works fine. However, if I use any of the other organizations, I get this error message. I think I am at least making some progress in the troubleshooting.....
thanks for that useful hint. I will have a look at it.
This problem will be fixed within version 4.0.10
