API Ability
rknott
API Ability
Beitrag von rknott »
Is there any API functionality available with Admidio currently so that I could send / recieve data from my storefront and/or email applications?
I didn't see anything indicating that there was, but I apologize I overlooked it.
Thanks very much!!
Re: API Ability
There is no API available.
rknott
Re: API Ability
Thank you for the quick response!! Is there any plan to incorporate one at a later date?
Thanks!
Re: API Ability
We don't have enough developers to integrate an API.
But if there will be someone, than why not :)
