Online membership management
plawrie
Beitrag von plawrie »
Having now gained access to the Amidio system I have been looking at the Online membership management page, which was the main reason I looked for a package solution.
Before I start fiddling and potentially wrecking the system, can I easily modify the user profile fields?
I note the "profile fields" which are listed
I want the address (street) split into four - address_1, _2, _3 and _4. I need a field for membership renewal and type of member.
Do I simply modify user_fields to achieve this? But surely the code would need to change too?
Finally a member number which has to be a unique key and set by us (not auto-generated).
Can I use the usd_user_id in user_data for this?
Finally, although I have not yet looked for the facility, I need to be able to extract the member data to csv
How easy would it be for me to make these changes?
plawrie
Re: Online membership management
Further to my message, I can now see how to add and modify user fields.
I have imported some user data from csv, but I can't see a way to export to csv.
Go to the groups and roles. There you can call lists of that roles. Within that lists you have the possibility to export those lists.
plawrie
Thank you. I can see how that works.
However, I used profile management to add some additional fields to the database. These fields appear for the members I have loaded to the system in online membership management.
However, when I use groups and roles, I can select the 71 members whcih have been loaded so far, but can only export the standard fields, not the additional fields which I added.
You can define in this module your own lists with profile fields that you have configured.
plawrie
Thanks for your previous advice. I am recommending to my Council that we use this software and that we make a contribution.
The only remaining issue I seem to be head-scratching over is gender and birthday. Neither of these are data which we hold or have any wish to hold. I deleted them from the profile list, but they still appear as empty space in the user management list. It's a waste of screen space which we would prefer to use for several of the fields we have defined as profile fields.
We have adressed this issue in the upcoming version 4.1. There you can define the profile fields that should be shown in the User management.
