Update to 4.1.2 not working for me
JonCope
Beitrag von JonCope »
Yesterday I updated from 4.0.6 to 4.1.1. but although the program ran only certain functions worked. I reported this via the Forums as well as messaging Fasse and I received a reply from Markus saying that several changes had been made which would be in 4.1.2 and could I install that and then try again.
I have done that, and now I can't get into the program at all.
The text of the error log is below. Can someone please tell me what to do?
Thanks!
[09-Jan-2022 17:20:16 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
#0 /home/chchcorg/public_html/admidio/adm_my_files/templates/compile/360ad50f20d6a27afc6a3cfba8dfc2035ce0ad78_0.file.overview.tpl.php(47): smarty_function_load_admidio_plugin(Array, Object(Smarty_Internal_Template))
#1 /home/chchcorg/public_html/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php(123): content_61d9c2c083b807_11950087(Object(Smarty_Internal_Template))
#2 /home/chchcorg/public_html/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_compiled.php(114): Smarty_Template_Resource_Base->getRenderedTemplateCode(Object(Smarty_Internal_Template))
#3 /home/chchcorg/public_html/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_template.php(216): Smarty_Template_Comp in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php on line 40
[09-Jan-2022 17:20:21 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:20:28 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:20:29 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:21:27 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:21:49 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:24:32 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
#1 /home/chchcorg/public_html/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php(123): content_61db1a501a1500_28120799(Object(Smarty_Internal_Template))
[09-Jan-2022 17:24:34 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:24:36 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
Stack trace:
Stack trace:
[09-Jan-2022 17:24:37 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:25:00 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:27:30 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:36:34 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/login_form/login_form.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
#0 /home/chchcorg/public_html/admidio/adm_my_files/templates/compile/360ad50f20d6a27afc6a3cfba8dfc2035ce0ad78_0.file.overview.tpl.php(31): smarty_function_load_admidio_plugin(Array, Object(Smarty_Internal_Template))
#3 /home/chchcorg/public_html/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_template.php(216): Smarty_Template_ in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php on line 40
[09-Jan-2022 17:36:39 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/login_form/login_form.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:36:40 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/login_form/login_form.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
Stack trace:
[09-Jan-2022 17:39:48 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/login_form/login_form.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:46:52 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:46:53 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:46:54 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
Stack trace:
[09-Jan-2022 17:47:04 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:47:17 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
[09-Jan-2022 17:47:19 Europe/London] PHP Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /home/chchcorg/public_html/admidio/adm_plugins/calendar/calendar.php ! in /home/chchcorg/public_html/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40
Stack trace:
JonCope
Re: Update to 4.1.2 not working for me
A correction to this post. By pasting a previously used URL I now find that Admidio 4.1.2 does run and everything seems to be working EXCEPT the Overview page:
https://www.chchoralsoc.org/admidio/adm ... erview.php
It looks to any user as if the whole program is not working, but it is, provided you don't try to access any page via the main Overview page. That only produces the following error:
This page isn’t workingwww.chchoralsoc.org is currently unable to handle this request.
HTTP ERROR 500
I would imagine this is a simple error to fix as everything else does appear to be working OK as I say. Any ideas as to what file needs what change?
By the way I have checked and the update has worked so that in Preferences / Update I see:
Admidio version
4.1.2 Check for update
Last step of update
960 / 960
Have you also updated the adm_theme folder?
Does the plugin / folder adm_plugins/calendar exists in your installation?
JonCope
Hi Fasse,
I can see the calendar file did not exist, and for some reason it was not in the extracted folder so didn't get uploaded. I have now unzipped it and uploaded it and all seems to be working OK.
Thank you very much Fasse. I didn't know where to start to work that out for myself so your help is greatly appreciated!
(And yes, I had updated the theme folder. )
A very useful program by the way.
Best wishes
Jonathan
