Restore backup
RogerLilley
Restore backup
Beitrag von RogerLilley »
I have a backup of a previous Admidio database which I wish to restore to a new database and on a different website. How can I do this, please?
Re: Restore backup
If your webhoster give you access to PhpMyAdmin. There you have the menu entry "Import" and you can select the backup file from Admidio.
Admidio itself could not import the backup.
RogerLilley
Re: Restore backup
Thanks
I can use php my admin and have restored the file using that, but (presumably) because the backup references a different url and database name, it does not work. I am still unable to restore the backup and for it to work on the new installation of admidio. I cannot use the original installation because the contract for that host has been terminated.
wisi01
Re: Restore backup
Beitrag von wisi01 »
Did you also change the settings in the file "config.php" in the folder "adm_my_files"?
Enter the correct values for host, database name, user name, etc. in this file
wisi
RogerLilley
Re: Restore backup
wisi01 hat geschrieben: 2. Feb 2022, 16:06 Did you also change the settings in the file "config.php" in the folder "adm_my_files"?
wisi
Thanks
Are the details in config.php those of the new installation or those of the restored backup. If the latter, where can I find them?
Re: Restore backup
This should be the data of your new system/ database.
RogerLilley
Re: Restore backup
I have checked all this. The php file is correct, but Admidio goes to a different log-in page which will not accept my administrator user name and password. I'm clearly doing something wrong here, but I would appreciate any advice you might be able to give me.
Re: Restore backup
Ok, the system goes to your configured default page.
You can go to the following page https://www.your-domain.xy/admidio/adm_ ... /index.php and than login. After login Admidio will go to your configured default page again, now enter that url again.
You can change the default pages within the preferences in the common area.
RogerLilley
Re: Restore backup
I must be being obtuse - but
1 My domain is not https// but http - does this make any difference?
2 You give the link as https://www.your-domain.xy/admidio/adm... /index.php. What do I do about the adm... bit?
Thanks
RogerLilley
Re: Restore backup
I have, at last managed to restore the database, and when I log into Admidio I get a white page which gives me all the functionality of the site (with the exception of "Preferences" - which is not available. All the data from the database seems to be in order, but the normal presentation of Admidio (the formatted pages) doesn't seem to be available. How can the basically white page be changed to the standard formatted presentation?
Re: Restore backup
Hmm, do you had a custom theme?
Do you have the folder adm_themes/simple ?
Could you give me a link to your page, so that I can have a view to your current layout?
RogerLilley
Re: Restore backup
link to the page is:
www.viasarum.co.uk/admidio3317
Thanks
Roger Lilley
RogerLilley
Re: Restore backup
I have just checked the files in admidio3317 and the only theme that is there is "modern"
Apologies for two replies
Roger Lilley
Re: Restore backup
Ok, you have done an update from version 3.
Therefore you should check https://www.admidio.org/dokuwiki/doku.p ... _version_4 and here in step 5 we recommend the update of the adm_themes folder.
Within your installation there is no version 4 compatible theme.
