ich hab mit der aktuellen Version 5.1.1 das Problem, wenn ich unter Export -> SEPA eine Vorabmail versenden will, kommt ein Error 500 "Failed to load resource: the server responded with a status of 500 ()"
Hat jemand ne Lösung?
Anbei das Browser Log:
$session = New-Object Microsoft.PowerShell.Commands.WebRequestSession
$session.UserAgent = "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/98.0.4758.82 Safari/537.36"
$session.Cookies.Add((New-Object System.Net.Cookie("'ADMIDIO_SGW_admidio_adm_cookieconsent_status", "dismiss", "/", ".www.xxx.de")))
$session.Cookies.Add((New-Object System.Net.Cookie("ADMIDIO_SGW_admidio_adm_SESSION_ID", "c1f5001bd61d5cc14eb461f4a873f313", "/", ".www.xxx.de")))
$session.Cookies.Add((New-Object System.Net.Cookie("ADMIDIO_SGW_admidio_adm_AUTO_LOGIN_ID", "0%3A0rWQNdEoEgiMLzO5tkps9vI5PTRm3wH3lz1qezeI", "/", ".www.xxx.de")))
Invoke-WebRequest -UseBasicParsing -Uri "https://www.xxx.de/admidio/adm_plugins/ ... c6c0fd05a2" `
-Method "POST" `
-WebSession $session `
-Headers @{
"method"="POST"
"authority"="www.xxx.de"
"scheme"="https"
"path"="/admidio/adm_plugins/mitgliedsbeitrag/message_send.php?user_uuid=4f72b09f-32c6-48a3-a7e1-a490b3fc7c73&usf_uuid=81a0bab5-53f9-4798-b8f8-9fc6c0fd05a2"
"cache-control"="max-age=0"
"sec-ch-ua"="`" Not A;Brand`";v=`"99`", `"Chromium`";v=`"98`", `"Google Chrome`";v=`"98`""
"sec-ch-ua-mobile"="?0"
"sec-ch-ua-platform"="`"Windows`""
"origin"="https://www.xxx.de"
"upgrade-insecure-requests"="1"
"dnt"="1"
"accept"="text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
"sec-fetch-site"="same-origin"
"sec-fetch-mode"="navigate"
"sec-fetch-user"="?1"
"sec-fetch-dest"="document"
"referer"="https://www.xxx.de/admidio/adm_plugins/ ... _write.php"
"accept-encoding"="gzip, deflate, br"
"accept-language"="de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"
Admidio-Version Installiert: 4.1.7
Mitgliedsbeitrag 5.1.1
PHP 7.4
Browser: chrome / edge / safari
Mitgliedsbeitrag
Re: Mitgliedsbeitrag
der Fehler ist in Version 5.1.2 behoben.
Super - funktioniert mit 5.1.2 - besten Dank für die schnelle Hilfe
Nach dem Patch Funktioniert die Vorabmail zwar, jedoch versendet das Programm die Daten des ersten Empfängers an alle Empfänger ...
Hallo made,
in der nächsten Version ist der Fehler behoben.
Als Übergangslösung bitte die entpackte, angehängte Datei ersetzen.
- message_send.zip
- (3.16 KiB) 1204-mal heruntergeladen
Hallo rmb,
besten Dank für die schnell Hilfe ... hat mit dem Fix jetzt funktioniert.
Grüße
made
Grüße
made
