4.1.11 does not update
jorola
Beitrag von jorola »
Hi.
There is no update message when updating from 4.1.10 to 4.1.11.
May be because the file in bootstrap constants.php still contains 4.1.10??
Is it ok to correct this?
BR Johnny
Re: 4.1.11 does not update
Yes you are right. Please change the version there and you will get the update notice. I will fix that soon.
