Plug in Update fehlgeschlagen
Hirtenjunge
Beitrag von Hirtenjunge »
Moin,
ich wollte heute ein paar Plug ins nachziehen, hat leider nicht geklappt:
Fatal error: Uncaught UnexpectedValueException: Invalid plugin file /homepages/30/d884704953/htdocs/admidio/adm_plugins/latest-documents-files/latest-documents-files.php ! in /homepages/30/d884704953/htdocs/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php:40 Stack trace: #0 /homepages/30/d884704953/htdocs/admidio/adm_my_files/templates/compile/062327c88a2a46025dde9f864cd00c9215d0c7cc_0.file.overview.tpl.php(63): smarty_function_load_admidio_plugin(Array, Object(Smarty_Internal_Template)) #1 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php(123): content_63f65468ab1e96_19106911(Object(Smarty_Internal_Template)) #2 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_compiled.php(114): Smarty_Template_Resource_Base->getRenderedTemplateCode(Object(Smarty_Internal_Template)) #3 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_template.php(217): Smarty_Template_Compiled->render(Object(Smarty_Internal_Template)) #4 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_template.php(386): Smarty_Internal_Template->render() #5 /homepages/30/d884704953/htdocs/admidio/adm_my_files/templates/compile/8fbcfba22031675e560842cf8e21540a7cdb7c87_0.file.index.tpl.php(220): Smarty_Internal_Template->_subTemplateRender('overview.tpl', NULL, NULL, 0, 3600, Array, 0, true) #6 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php(123): content_63f3e3582e5b98_78920041(Object(Smarty_Internal_Template)) #7 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_compiled.php(114): Smarty_Template_Resource_Base->getRenderedTemplateCode(Object(Smarty_Internal_Template)) #8 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_template.php(217): Smarty_Template_Compiled->render(Object(Smarty_Internal_Template)) #9 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(238): Smarty_Internal_Template->render(false, 1) #10 /homepages/30/d884704953/htdocs/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(134): Smarty_Internal_TemplateBase->_execute(Object(Smarty_Internal_Template), NULL, NULL, NULL, 1) #11 /homepages/30/d884704953/htdocs/admidio/adm_program/system/classes/HtmlPage.php(471): Smarty_Internal_TemplateBase->display('index.tpl') #12 /homepages/30/d884704953/htdocs/admidio/adm_program/overview.php(29): HtmlPage->show() #13 {main} thrown in /homepages/30/d884704953/htdocs/admidio/adm_program/system/smarty-plugins/function.load_admidio_plugin.php on line 40
Re: Plug in Update fehlgeschlagen
Es wäre noch hilfreich zu wissen, welche Plugins du nachgezogen hast.
Noch eine Anmerkung zu deinem Log:
Dort tritt ein Fehler bei der Anzeige unseres Standard-Plugins latest-documents-files auf. Da bin ich doch sehr verwundert, da dies eigentlich funktioniert und bisher noch keiner einen Fehler zu gemeldet hat. Hast du da evtl. irgendwas angepasst / ausgetauscht?
Hirtenjunge
So jetzt nur noch dieser Fehler:
Parse error: Unmatched '}' in /homepages/30/d884704953/htdocs/admidio/adm_plugins/awards-2.0.0/awards.php on line 12
Hirtenjunge
Ich bin leider immer noch nicht weitergekommen, bitte helfen.
Hirtenjunge
Die Lösung:
In Zeile 11 fehlte eine Klammer.
Bildschirm­foto 2023-02-28 um 19.56.14.jpg (103.88 KiB) 30401 mal betrachtet
