config.php location
isleofwight
config.php location
Beitrag von isleofwight »
Where is the Config.php? it is not in the adm_my_files and cannot locate with search.
Wiki says: Like many other programs Admidio also provides a central configuration file, in which the most important settings are stored. You'll find the file in the folder adm_my_files ......
I need access to change database link details (password, username, etc) or is there another way of accessing this without having to reinstall?
Re: config.php location
Which installation of Admidio do you use? Docker or something else?
isleofwight
Using 4.2.11 version and standard installation:
Now call the installation script on the webspace at the following url www.your-domain.org/admidio/index.php and select the language in which the installation wizard and the program should appear later. The language can be changed after the installation.
Then there must be a config.php within the folder adm_my_files
Orherwise Admidio could Not work.
isleofwight
This is very strange as only config file in adm_my_files is config_example.php I have ensured all system and hidden files being shown but no config.php
Did you successfully finished the installation process:
https://www.admidio.org/dokuwiki/doku.p ... stallation
The config.php will be there if you have installed Admidio successfully.
isleofwight
Simple amateur mistake!!! On my PC no config.php listed but on the web server the config.hp was there. Silly mistake and now corrected. Thank you for your patience.
