Extra country field on registration form
haman
Beitrag von haman »
Hi every one,
how can I add an extra country field on the registration form as the existing one? I did it with datatype Text (100), but it is showing just a textfield not a combobox/dropdownlist. I try do it with the datatype Dropdown-Listfield, but that means I have to provide manually the countries-list. Is there another way to do that?
Thank you for your help.
Haman
Re: Extra country field on registration form
Hi Haman,
it's not possible the create a secound country field with the country list. That is a special field which could not be configured.
