Membershipnumber on overview
termohe
Beitrag von termohe »
Can I add a Membershipnumber and show this on the members overviewpage rather than the 1,2,3,4 ?
Re: Membershipnumber on overview
You can configure your own profile fields:
https://www.admidio.org/dokuwiki/doku.p ... ile_fields
robinson_pj_ssea
Beitrag von robinson_pj_ssea »
Thank you for this, Fasse. It does help with my own question (relating to $usr_id field in the adm_Users table). But if I create a user defined field myself, in numerical form, is it possible to auto-increment it, perhaps by using the 'regular expression' option when setting up that field? Ideally, though, since the $usr_id field in the Users table is already indexed and auto-increments, I'd prefer to use that instead. That way, any of my 'membership secretaries' will generate a new member from their list of prospective applications, without having to allocate the membership number from a central list of numbers, since the MySQL table will do all the work for them.
Thanks
Peter Robinson
Webmaster, SSEA Canada
