Error 500 after upgrade to 4.3.0
jorola
Beitrag von jorola »
Hi.
I Get http error 500 accessing adm_program/overview.php after upgrade to 4.3.0 from 4.2.13.
This happens after update of database, which seemed to work.
BR Johnny
From error log: (client and site anonymized)
Log in reverse order.
[13/Jan/2024:09:50:35 +0100] [client w.x.y.z] [host xxx.yy] [host xxx.yy] Backend log: PHP Notice: Undefined index: menuSidebar in /var/www/xxx.yy/public_html/Medlemmer/adm_my_files/templates/compile/8444236a766465c8e3694349868185db9517437a_0.file.index.tpl.php on line 165\n
[13/Jan/2024:09:50:35 +0100] [client w.x.y.z] [host xxx.yy] [host xxx.yy] Backend log: [2024-01-13 09:50:35.992740] Admidio.ERROR: L10N: Could not found text-id! {"textId":"PRO_MY_PROFILE"} {"file":"/var/www/xxx.yy/public_html/Medlemmer/adm_program/system/classes/Language.php","line":115,"class":"Language","callType":"->","function":"get"}\n
[13/Jan/2024:09:50:35 +0100] [client w.x.y.z] [host xxx.yy] [host xxx.yy] Backend log: PHP Notice: Trying to get property 'value' of non-object in /var/www/xxx.yy/public_html/Medlemmer/adm_my_files/templates/compile/8444236a766465c8e3694349868185db9517437a_0.file.index.tpl.php on line 165\n
Re: Error 500 after upgrade to 4.3.0
Du hast wahrscheinlich nicht die Anpassungen am Theme vorgenommen bzw. den Theme Ordner aktualisiert.
jorola
OK, You are quite right.
But the step of deleting the Theme folder and update this too, is not presented in the readme.md file.
So this is easily forgotten, if not reading the online documentation.
Suggest the readme.md file steps for updating is changed to be:
1. Delete the folders "adm_program", "adm_themes" and the "index.php" of the previous version.
2. Copy the folders "adm_program", "adm_themes" and the "index.php" from the new version.
3. Adjust the theme in the "adm_themes" folder if necessary.
4. Update the "adm_plugins" folder with the newly delivered plugins.
5. Access the "index.php" in your Admidio folder to initiate the update.
BR Johnny
Your right. I will improve the md file.
Sorry for responding in german in the post before.
jorola
Hi Fasse.
Thanks and ok, following some series on NDR and ZDF, so do understand a bit.
(with DK subtitles).
BR Johnny
