Import CSV file of new contacts fails.
LMTAdm
Beitrag von LMTAdm »
New installation, new user. I am trying to import a CSV file of contacts and I receive this error: This page isn’t working. Website is currently unable to handle this request.
HTTP ERROR 500
I've found posts regarding earlier versions of Admidio but no recent posts. I've inserted a 0 in the ID column. Verified UTF-8. I have exported a Google Sheets file as CSV and also made modifications in Excel and exported as CSV. I would appreciate any advice. File permissions on server are 775.
LMTAdm
Re: Import CSV file of new contacts fails.
Self resolution:
The error indicates this is a server side error.
I activated PHP error logging by adding the following lines to the /home/webpage/www/www/php.ini file:
error_reporting = E_ALL | E_STRICT
log_errors = On
display_errors = Off
error_log = /home/webpage/private/php-errors.log
This configured the server to save an error log in the /home/webpage/private/php-errors.log file. The following error was recorded in the file after a failed import:...
Specifically some of my phone numbers had "." which are not allowed.
Hi, thanks for this analysis. I will try to handle this error better in future versions so that you get a response and not a blank page.
