Video and IFrame
owebsmart
Video and IFrame
Beitrag von owebsmart »
hi!
I am wondering how we can incorporate video from You Tube in the CK editor you are using. can we adapt the editor config on our own to include an IFRAME option? or do you have a plug in for adding you tube videos, and or iframes?
I am quite familiar with ckeditor as I use it my my own projects.
Please advise
thanks!
Owen
Re: Video and IFrame
Hi Owen,
yes you can manipulate the adm_program/libs/client/ckeditor/config.js for your needs. But remember to not override this file during system update or you must reset your settings.
owebsmart
thanks!
I did try that ... however when updating the iframe disappeared, i.e. stripped out of the content. I'm guessing there is some kind of restriction on update. how do we get around that?
still waiting for an answer to this.
